Deauth other AP's on same channel
akb
Is it possible to somehow set up our routers to run a script which will send deauth packets to other AP's which hop on the same channel? I have 2 neighbors who's routers are most likely on auto channel, and every so often they hop to my routers channel. I normally just use my laptop and deauth it for 30 minutes and it will hop back to an unused channel. Would be nice to just automate this.
It would be nicer if you found another, less illegal way to deal with the situation.
Don't do that - sending a DEAUTH packet disconnects everyone...
You can actually target specific macs.
Just don't do it - if I were your neighbor and that happened - there would be some pretty strong words, and perhaps fisticuffs ensuing thereafter...
