metaprogressor
Couple days ago out of sudden I started experiencing constant disconnects of my D-Link DWA-182 Wireless AC adapter.
It happens every 10-15 minutes. In the middle of browsing the pages stop loading and exclamation mark appears on wireless signal strength in tray.
If I right click on it then I see "Limited connectivity" in front of my SSID. I right click on wireless indicator icon again and choose "Troubleshoot problem". Windows runs fix and tells me that problem was "Default gateway is unavailable".
After repair it works for another 15 minutes and then problem reappears.
I use 3.0.0.4.354.27 build, Windows 7 x64, Ipv6 is disabled, modem connected to router through Cat6 patch cable, tried different wireless G adapter with no luck. Tried Linksys E4200, still the same.
Problem happens when either automatic or manual ip is selected in adapter settings. MS Security Essential antivirus, no third party software were installed. Tried all fixes and patches from online (about 10-15 of them) like flushing DNS, resetting TCP/IP, reinstalling wireless adapter drivers, resetting routing tables, 6to4 tunneling fix, etc.
Anybody has the same issue? Never ever I had such a hard time with computer since 1996. My next step will be reinstalling Windows. But before that I would like to find what the hell happened...
