Default IPv6 Tunnel 6to4 Setting
erwinquek
Can help to check the above? I have them as:-
IPv4 Anycast Relay: 192.88.99.1
Tunnel MTU: 0
Tunnel TTL:255
DNS: Blank
Enable Router Advertisement: Enable
you need to fill in the dns servers
google
2001:4860:4860::8888
2001:4860:4860::8844
opendns
2620:0:ccc::2
2620:0:ccd::2
google
opendns
2620:0:ccc::2
2620:0:ccd::2
Thanks ... strangely, I can access IPv6 sites even without a gateway and DNS.
I might have messed some settings up. When you select Tunnel 6to4, are these the defaults?
Tunnel MTU: 0
Tunnel TTL:255
DNS: Blank
Tunnel MTU: 0
Tunnel TTL:255
DNS: Blank
yep, thats what I have.
