Delete/edit OpenVpn Clients AC68u
jak8
Can anyone advise if it is possible to either delete or edit an existing OpenVpn client on the AC68u. I attempted to setup the router such that when selected only my NAS was routed through the vpn. This took me 3 attempts - 3 differents clients - but was functioning satisfactorily for about a year until PureVPN changed their ovpn details. One of the openvpn clients is still functioning but at a max of 2mb/s which is far from ideal as I normally would achieve 20 - 35 mb/s. There is space for another 2 client setups but ideally I would prefer to remove/edit the non functioning clients.
I am currently on 380.63_2 and presume I should upgrade to a more recent firmware. Can I simply SSH into the router and delete the relevant sections from nvram? As you will probably appreciate from the above I only have a relatively elementary appreciation of IT.
You can set the client or server to default that will do it.
