I would only try this action IF .. the router- IQrouter in my case, would then free up more bandwidth for the single Wireless 5G Interface? Question based on likely false notion that some level of bandwidth, or ??? is reserved for each radio/ band?
Before offering up any of a couple dozen screenshots, and/ or data samples, I just wondered about going one step further than a simple "Disable", to a Remove or Delete choice for the 2.4G Radio Interface? Pretty sure it's an option in the IQrouter. I know you can reName each band, but thought I saw a Delete button. Sorry, I should've double checked
The back story; Basically, the last real positive improvement to our home network; upping from 12mb to Bonded 25 mb service. (Actual line rate always shy of 22mb)
The next 2 "moving UP" choices- Dual Band w/ ActionTec T3200, and then adding the amazing?, most "intelligent"?? IQrouter (in the -> DMZ of the A'Tec).... were both let-downs with very disappointing results.
When moving to Dual band and the ActionTec T3200, general browsing seemed slower, downloads- slower. I was curious about having to choose one
of the 2 Wifi bands, which led to giving the A'Tec "Band Steering" control. I hoped for something better. If anything, it was worse!
Then, reading all the love (elsewhere) over the IQrouter.... I went for it. The price made it "comfortable", but seemed a tad low to match the hype. A 20%+ drop in "effective"(not actual term) Line Rate- @ 16.03mbs, and not at all any faster than before! By the way, the sum of the 2 line rates reported by the A'Tec (1st Dual Band) very nearly = the 21-22mbs Rate shown after 1st "bonding" with a Sagemcom 4320. And the "attainable " rate reported by the IQrouter is also near 21+mbs. In other words our Line Rates from Windstream have held up.
Rather than put the A'Tec in Bridge mode, the instructions simply have you turn Off it's Wifi and enter the IQr in it's DMZ. That means DHCP remains ON for the ActionTec (why??), and its also doing NAT, at least so I think.
Perhaps I've been too focused on that max. of 6mbs Tx Rate, as reported by the IQr for all network devices, considering our Upload rate is barely 1 mb? The Rx rates for all never drop below 24mbs, and sometimes jump much higher. Bugs me though, ...not often will the 40 Mhz ch. Mode appear in any device's stats. And that's on *5Ghz band* only, with Mode set on 80Mhz (default)
