detect wifi connected devices on aimesh node
Gravityz
Hello,
i have a very nice script running on my router which detect all the devices which are connected to the RT-AX88U router.
i use this for geofencing purposes
problem is that if a device switches from the router to another aimesh node it is not detected anymore.
is there some kind of way to detect a device from the original router when it is connected to another aimesh node?
on the gui this is easy to see(just click the aimesh node) but from a script/commandline i can not find a way
Hello,
What type of aimesh nodes are you running? Could you run the script on them?
iamesh node is RT-AC86U
i could run te script on them as well but then i need to create a second ocupancy switch because they can not control the same switch.
At the moment i am experimenting with homekit ocupancy to see is there is somebody home. that seems to work fine for multiple people in my home.
e.g. when somebody comes home turn on the thermostat/lights
when everybody has left turn down the thermostat/lights.
so now i have a switch created in domoticz which is controlled by homekit instead of my router script.
let's see how accurate/stable it is (eg hopefully no flukes from icloud)
