I have an RT-AC88U Router than has been working fine with 20 devices regularly connected via WIFI. I recently installed a smart Orbit sprinkler controller, which connects via 2.4GHz to the Router. My issue is that whenever there is a power outage or cable outage, my Honeywell Smart Thermostat won’t connect via 2.4GHz to the Router. I’ve traced the problem to a conflict between the Orbit and the Thermostat. If I unplug power to the Orbit, the Thermostat will connect to the Router. I can then plug in the power to the Orbit and it will connect, so both devices then work correctly. I’ve been able to duplicate the problem & the fix. Note, both devices only work on 2.4GHz.
Is it possible to make changes in the Router so I no longer have to unplug the Orbit to get the Thermostat to connect? I’m no Router expert, but my guess is if I assign a fixed IP Address to one or both devices in the Router, this may work? Appreciate any help here.
