whippoorwill
Dear Friends,
I have an odd problem all of a sudden. Earlier most of my devices, most of which are new, were connecting to the 5GHz band by default. Suddenly, and I can't pinpoint what exactly caused this, but now many of them prefer to connect to the 2.4GHz band. Don't know why. After that I decided to give merlin a try, to see if it would solve the problem. I upgraded to merlin latest stable firmware on my RT-AC88u, did a factory reset of the router, and configured some simple settings like AiProtection (on), WPS (off), UpnP (off), SMB server (off), Cloudflare DNS, 160MHz band (on) and a few others but nothing major. I have been using computers and routers since several years but I can only configure some basic router settings -- not at all anything like SmartConnect etc. without help. But SmartConnect is enabled of course as I have a few kindles and older devices that work only on 2.4GHz. And I live in a very small house, so it is really beyond me why the newer ones need to connect to 2.4GHz.
To clarify, this never happened before, and 2.4GHz gives a significantly slower speed with buffering on youtube, etc. I am also not blaming it on merlin, as it started happening suddenly before I decided to install merlin.
Please forgive me if this has already been discussed before, but I looked and looked and couldn't find any answer remotely related to this on this website or the internet. I do not use proxies or a VPN. Mr modem, router, and wifi network are protected by strong passwords.
Edit: Please note that I did find one solution which was to block a device from using 2.4GHz using MAC id filtering or something, but it appears cumbersome to do so for all of them.
Also, one thing I did not do was to do a factory reset BEFORE installing merlin. Should I do that and remove merlin and check? Thanks.
Please help me. Thanks!
