Is anybody successfully using DFS in the USA?
My son has a DG2470 with RCN in Chicago. The WIFI on that 3-in-1 router is horrible and I will be giving him a spare R7800 to use as a Wireless AP. The 5GHz channels are heavily used around him in the low (UNII-1) and high (UNII-3) ranges. There are 1 or 2 DFS channels that show up used as well, but far fewer. For that reason, I am considering using DFS channels, but never have in the past.
What channel and width are you using, and where are you located?
Is DFS as reliable as non-DFS? For example does it lose connections or need to be rebooted?
Is there anything else to watch out for compared to using non-DFS channels?
Do the DFS channels use much less power and have less range than non-DFS channels?
Any DFS channels better or worse than others? Are there some to avoid (like weather)?
Any client issues to watch out for?
Any comments or advice are appreciated.
