[SOLVED] DHCP handing out router as DNS server no matter what
So I've changed DNS under DHCP on my router, rt-n66u, to my linux box running bind, and when my computers renew DHCP, they have both the router and my bind server listed for DNS.
I enabled ssh to look around for dhcp but I was unable to find any config files. I have enabled jffs so I can overwrite the config file I need.
Where is the config file for dhcp? I found dnsmasq.conf and thought that was it because it had an entry that looked like it might be the culprit but it wasn't.
I think I'll be set if I just knew where this damn config file is for dhcp.
