DHCP Manual assignment
clvk07
Hi
It seems that the DHCP doesn't assign an IP address which I have set to assign manually to a device, Any reasons why it shouldn't do that? I have set it to 192.168.1.21 but it seems to get 192.168.1.128 (AC88U, 382.2)
If it already had 128 then it will keep getting it until the dhcp Server is restarted or the life of the address runs out in my experience
Make sure you hit apply after assigning your ip's. You can also reboot your devices and then the router and it should assign your manual ip's right away.
