dhcp option 60
Symbiot
Any way to set this on the ac66u?
I want to pxe boot on my synology (mdt boot image) and am getting some error pretaining to option 60 missing from the synology pxe server broadcast.
Is this LAN-> Route I need to configure? if so.. what do I need to enter into the config?
I run my Qnap as PXE server and on my RT-AC66U I copied /etc/dnsmasq.conf to /jffs/configs/dnsmasq.conf and added the line dhcp-boot=pxelinux.0,,192.168.0.253 (192.168.0.253 is the NAS) this is working.
While this works, I recommend using either dnsmasq.conf.add to add that single line, or a postconf script instead. That way, if Asus makes any change to the generated dnsmasq.conf file in a future FW release, you will still get the most up-to-date basic config from the firmware.
