DHCP range not accepted
Geedsen
Just received my AX6000 to replace a RT-AC87U. So I am configuring it for swapping it. I have a lot a devices at home and a lot of them have a fixed addresses (because of a home automation system). So it is important that the configuration is very similar to the old router. I connected the new router on the WAN port to my current LAN. Opened up the admin from the WAN , so on my PC I can now have both the new and the old admin sites open. So the first thing I wanted is to make sure that the DHCP range is the same as on the old router: 192.168.2.64 to 192.168.2.254 (I was not sure it would allow me to do that because it would be in the same range as the current WAN ip address). But it tells me 192.168.2.64 is an invalid ip address. But it looks like any other ip address I try is invalid as well. 192.168.3.64 anything except the 192.168.50.* range that was the default. Is this supposed to be working like this? If I google for valid DHCP ranges I see a lot of other possibilities. And reconfiguring my home automation system to use totally different ip addresses is a not a good idea.
I was afraid of that as I said. So I need to figure out how I can access both at the same time. I have to copy a lot of mac addresses so dont really feel like typing them. Thanks
You don’t need to. Copy all DHCP reservations table, paste in an Excel file. Multiple methods to transfer DHCP reservations manually. Some folks use screenshots, some export/import in SSH… whatever method works for you and you are comfortable with.
Might be a whole lot easier to assign those clients with a real static IP address and forget the manually assigned IP addresses.
