Hello all,
I bought an RT-N66U a while ago and I am really happy with it so far. It did not take too long to flash the merlin build: Really good job RMerlin, thanks for this alternative to asus firmware!
Now, after moving houses, I want to change my network in which, my intenet modem is the gateway and the router is the dhcp server but without wan connexion. so I disable the wan and setup the DHCP server so that the dns server and the gateway are the modem. that works perfectly appart from a small thing: when I plus a linux workstation to it (my own desktop)
for some reason, th dhcp server returns 2 dns servers: 192.168.0.1 and 192.168.0.254 (first the real gateway, then the router itself)
this configuration does not work ... but on windows machines and android machine, it works perfectly
So i am wondering how to disable in the router the broadcast of its own ip ?
I hope my problem is clear...
Cheers!
Cheers!
