TLDR: I'm trying to assign a static IP address to each of my VPN clients. I need to be able to reliably connect to them by a LAN IP address that does not change.
Long version: I have a raspberry pi with a 4G dongle that automatically connects to my VPN when powered on. I also have a laptop that I use to connect to the VPN, and from there I connect to the raspberry pi. I need to make it as simple as possible so that the RPi lan address is always the same. So I basically need the router to assign it the same address every time it connects to the VPN just the same way I'm able to assign computers hardwired to the router (or via wifi) with DHCP.
The raspberry pi is on a drone. The computer is the control PC with the navigation software (as well as receives streaming video live from the PI). Once they are connected to the VPN, I start the control software which SSHs a command to the RPi that starts a program on the pi that controls the drone. It automatically connects to the IP that sent the command via SSH. So the IP address of the computer isn't nearly as important as the IP address of the RPi.
I know of no way to do this with the current asuswrt-merlin, but I'm sure there must be a way. Please enlighten me.
Also, (and unrelated) an external ip checker for the DDNS updater would also be a nice addition for us folks operating in a double-NAT system. Thanks!
