DHCP Static-Lease Configuration from Command-line
gatorback
I would like command-line ability to configure the static leases found at the tail:
http://Router_IP/Advanced_DHCP_Content.asp
It would look something like:
https://www.dd-wrt.com/wiki/index.php/Static_DHCP#How_to_add_static_leases_into_dhcp_by_command
  1. Set the number of lease slots
  2. Fill in the data for each lease slot
I set one static lease and tried:
router:/tmp/home/root# nvram show | grep static
vpn_crt_server2_static=
vpn_crt_client1_static=
size: 47431 bytes (18105 left)
vpn_crt_client2_static=
vpn_crt_client3_static=
lan_proto=static
dhcp1_staticlist=
vpn_crt_client4_static=
dhcp_staticlist=<99:52:99:22:9D:5B>192.168.8.110>MyHostname
dhcp_static_x=1
vpn_crt_client5_static=
dhcp1_static_x=0
vpn_crt_server1_static=
I set a second static host
dhcp1_staticlist=
lan_proto=static
dhcp_staticlist=<99:52:99:22:9D:5B>192.168.8.110>MyHostnameF<99:02:AF:72:CA:5B>192.168.8.111>NextHostname
dhcp_static_x=1
dhcp1_static_x=0
size: 47479 bytes (18057 left)
My Google search was not successful and I hope that others have already published this info. I look forward to seeing how this is done. Thanks
You need to restart dnsmasq to pick up the change,
service restart_dnsmasq
You'll probably also need to manually force the client to renew it's lease.
You need to restart dnsmasq:
This is probably as good of place to start as any - dnsmasq is the dhcpd that sets leases...
OpenWRT info - https://wiki.openwrt.org/doc/uci/dhcp
Thanks for putting me on the right-track. Is there a good example that's applicable to Merlin's 378.58 on an RT-AC78U: I would prefer to be certain that I am doing this correctly and avoid an accidental borking of other services (DNS, etc.) I'd also like to understand where this configuration information is stored (NVRAM?) Thanks
I wouldn't use that page as a guide if I were you. OpenWRT uses a different method to configure DNS/DHCP with a different syntax. It's better to look at: http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html
The ASUS uses the "normal" dnsmasq configuration file at /etc/dnsmasq.conf. The firmware builds this file (and others) based on NVRAM settings at boot time.
For example, look at options --addn-hosts (/etc/hosts.dnsmasq) and --read-ethers (/etc/ethers)
