Pyheme Guate
Hi all,
I've recently updated by Cisco E3000 router for a ASUS RT-AC66U, now running Asuswrt-Merlin 380.57 firmware.
After a while playing with it and reading various posts on this forum, I was able to set it up, in the last few days, as I need it to work, including my OpenVPN client on the router and configure custom routes to use it as well as port forward to my ipcam on the router's LAN.
The ASUS router is connected on the WAN side to the ISP's issued modem on 192.168.0.0 subnet and issues IPs on the LAN side on the 192.168.2.0 subnet.
Just when I thought that I was all set, I noticed today that my PC was issued today an IP address from the ISP's modem (192.168.0.15). Connecting my cellphone, the same happened. Turning off the DHCP server on the ISP's modem resulted, as expected, in clients being unable to connect as no server provides them an IP to use. All machines with fixed IPs continue to work seamlessly.
Setting a fixed 192.168.2.xxx address in my PC gives me access to the ASUS router and to the Internet. Rebooting the ASUS router (from the reboot button in the admin panel) does not solve the problem.
Re-applying the DHCP settings does solve the problem, temporarily. It is the 2nd time that this happens to me. It seems to stop working after a day or so. The first time, I assumed I did something wrong as I was playing around was other settings. This time, I haven't touched the router for a couple of days and everything else seems to work.
I haven't seen any post regarding this problem. I am the only one to face this bug or is it really a 'user problem' caused by me not having seen an obvious setting somewhere?
Below are my LAN settings.
Thanks for any pointers that you could give me!
Pierre
Pierre
