Difference between 80Mhz and 20/40/80 Mhz
neil0311
Using Asuswrt-Merlin 376.48.1 on RT-AC68P. On the 5GHz wireless configuration options, the bandwidth can be set to 20MHz, 40MHz, 80MHz or what appears to be an auto setting of 20/40/80 MHz.
Is 20/40/80 an auto setting? Is there an advantage or penalty for using 80 or 20/40/80? Mine is set currently to 20/40/80, and it looks like N clients and AC clients work correctly. What's best practice?
Doesn't really matter on the 5 GHz band, due to the low amount of interference, so 80 MHz should be fine.
Just a hint for apple users:
Not using strict 80 GHz band for apple devices (such as my iPhone, iPads, MacBook Pro's) was my solution to solve wireless disconnects and connecting problems with my asus router.
Thanks. So the 20/40/80 setting is an "auto" that will step down bandwidth in response to interference or other conditions that prevent 80MHz?
That's my understanding. I have tried it set to 20/40/80 and then when I look in the wireless log, I see that it has set itself to 80 MHz bandwidth. The wireless log reads exactly the same as if I set it to 80 only. And my AC devices connect at full speed either way.
I assume that, if there was another strong 5 GHz signal, it might only do 20 or 40.
This is analogous to how the settings work on 2.4 GHz. 20 forces 20 only. 40 forces 40. 20/40 uses 40 if there are few other signals but goes to 20 otherwise.
