Lotta Cox
I just got a AXE-16000.
I don't know why I get much better wired download speeds with a AX6000 compared to the AXE16000. Is it because my Comcast IP changes?
It must be. This is wired 2.5Gps wire LAN connected properly. I have tried setting the 16000's WAN port to the 10G port and the 2.5G port. Same speeds.
Each one gets its own IP after every swap. The 16000 gets a 73.xxx.xx.x and the 6000 gets 68.xxx.xx.x
I have used a lot of different speed tests, fast.com, speedsmart, speedtest.net, etc,
Also downloads with 20 connections. So it's not just the speed tests.
The 6000 hits 2Gbps in seconds. With peaks of 2.4. I'm on a Comcast 2G
The 16000 most times barely hits 1Gbps. With a max if 1.4Gbps.
This occurs every time I swap them.
What is causing this? Could it be the IP change or the router?
This is driving me nutz
The AXE-16000 is on the left side. The AX-6000 is on the right.
