J
justin2net
Guest
I am primarily looking for the best bandwidth and range out of the two. QoS and wired routing speed is not a issue; it will function purely as an access point for wireless-only clients. (pfSense and dedicated switch)
Which one has the higher bandwidth? About 70 percent of the clients have N cards (4965, 5100, 5300, Atheros) and the rest G. Currently I am using a WRT54GS v1.0 (since 2004?) and there are some routing/speed issues (~2 MB/s, lots of latency, running Tomato firmware).
I've read that the 655 is 2.4 ghz band only, the 4500, dual band. I would've just purchased the 4500 but they are kind of old models...so perhaps asking here would be a good idea.
It will be for transferring/streaming media. No other Wifi networks in the vicinity. I can keep the WRT54GS for G access only if that would be a good idea (?)
The price difference is relatively small, so if the 4500 is worth the $ in the long run then so be it. Or look for some other models?
