Disable NAT - IPSEC tunnel did not connect estabilished
pepeEL
Banned
When i set NO on the function ENABLE NAT in section WAN i have no internet on my device i lan and wireless. Why ?
I try this disabled because i can not run tunnel IPSEC to other router...(DRAYTEK VIGOR). When i connect my PC with out router ASUS i can connect with no problem. I try this on notebook with WIn 7 x64 Pro and PC with Win 8.1 x64 Pro. On all is problem. Can you help me...please ?
Merlin 374.39 ASUS RT-AC68U
Because that's what NAT does: take one public IP from your ISP, and allow multiple clients using private IPs to share that same public IP.
I have a static public ip adress from ISP
I dont understand what does it mean.
Wysłane z mojego SM-T311 przy użyciu Tapatalka
I recommend you read up on NAT before you dive into something as complex as IPSEC - you seem to be missing some very basic networking concept there (no offence).
