Glenn Freidet
Hi. If I disable NAT, shouldn't I be able to use the same subnet on both sides of the router?
I currently have a Merlin router with a typical gateway setup. I want to put a Tomato router between the WAN side of the Merlin router and the Internet to handle advanced QOS and IP monitoring. In order to do that, I think I need to have the Tomato WAN port face the Internet with NAT enabled. Then connect the LAN side of the Tomato router to the WAN side of the Merlin router with NAT disabled. I think everything needs to be on the same subnet to get what I need. Also, I'd prefer not to covert the Merlin router into an AP.
Thoughts?
Thoughts?
