Disable only 2.4 ghz
wyse
Hello,
i am on RT-N66U_3.0.0.4_270.26b FW. Thanks Merlin for his great job.
I have a question about wireless, is it possible to disable 2.4ghz and keep only 5 ghz wlan ??? How ?
thanks of help.
Yes, it's possible! Go to the login page off your router and login.
select wireless (advanced settings) and go to tab professional.
select the correct frequency (2.4 GHz) use the radio button no by enable radio. goto apply and you should be done. Cheers!
Hello,
thanks of help.
Go to Wireless -> Professional Tab -> Frequency (Select 2.4) -> Below that is Enable Radio -> Select No -> Click Apply at the bottom. 2.4 is now off
Thanks frogger and raptor.
it's really simple, but I never thought to see in the professional section. The interface logic sometimes baffles me.
