BruceCleghorn
Hey Chaps, hope you are all well
I run a 5 Node Mesh 1xRTAX88u Master with 4 slaves (RT-AX56U)
I've recently got into Home Automation in a Big way and I am using ZIgBee Wireless devices; for those that don't know these are very low bandwidth network devices running on their own 2.4GHZ WiFi Mesh; it's not possible for ZigBee to piggy back on the ASUS WiFi
Everything is pretty stable but it could be better. I'm manually able to select in ZigBee the 2.4GHZ WiFi channel I want to use (Industry recommendation is WiFi 2.4GHZ channel 25); which means if I can stop the ASUS WiFi using 2.4GHZ channel 11 then I'll have no 2.4GHZ overlap on any of the WiFi channels
I run vanilla code (not Merlin)
My question is, does anyone know of a way to select/deselect what channels the ASUS router is using (I can't find anything in the GUI)
Or does Merlin support this feature
Thanks everyone, sorry for the wordy question
Regards
Bruce
Regards
Bruce
