Disable unused services
Edoardo
Hello everyone, new member here. I've been messing with this Merlin firmware for few days, now I started looking at the running services that bind to some port (confirmed with an nmap scan).
Since busybox's netstat doesn't seem to have the -p option i installed entware and then lsof to see the actual processes.
I managed to disable the printing service (since I don't use it) but I still have some processes for which I don't know the reason to be on:
wanduck: managing the wan inferface, ok but even if i disable browser redirection it's still bound to tcp/18017 and udp/18018
ots: setup for wireless access point, tcp/9998
cfg_server: port tcp/7788 and udp/7788, unknown?
eapd: udp ports 38000, 42000, 43000, 59000, used for some enterprise wifi authentication?
infosvr: udp/9999, used for router discovery?
Lastly there is syslogd which binds to a random udp port, at first I thought about the feature that sends logs to a remote server, but in this case syslogd would act as a client.
Note: even if those processes bind to 0.0.0.0, they are not open on the WAN side but I don't see the point on having them listening on the LAN anyways.
Should I disable them via jffs script or just firewall them with iptables (ex. below)?
iptables -I INPUT -p tcp -i br0 -m multiport --dports 7788,9998,18017 -j REJECT
Most of the non-essential services have been discussed previously in the forum (or if not then you may review the source code on GitHub)
e.g. most recently:
[Beta 384/NG]Known services that can safely be stopped
However, I believe unless you don't use wireless then eapd shouldn't be stopped?
What is cfg_server
Any way to turn off cfg_server permanently?
Thank you for the links! I think eapd may only play a role if you use WPA2-ENTERPRISE, not for the typical wifi usage. Not sure if stopping would break the whole wifi stack though.
What about syslogd? Is it supposed to be listening too?
ps | grep syslogd | grep -v grep
syslogd --help
tail -f /tmp/syslog.log
Do you still want to kill the task? :rolleyes:
Definitely not ;), in fact I was wondering about the listening port
Have you enabled
Remote Log Server xxx.xxx.xxx.xxx Port: nnn
on the System Log - General Log GUI?
Does the listening port go away if you restart syslogd?
Have you enabled
I do have a Remote Log Server set up, but as I said in the first post, in such case the router is acting as a client. Port is still there even after restarting BTW.
Do you have a listening port as well?
Only when I 'configure' the Remote Log Server.
i.e. any junk that looks like a valid IP address in the field (Bug?! :eek:)
lsof -i | grep syslogd
syslogd   29817  admin    5u  IPv4 2749588      0t0  UDP *:44222
29817 admin     1408 S    /sbin/syslogd -m 0 -S -O /tmp/syslog.log -s 256 -l 7 -R 255.255.255.255 -L
