"Disassociated because sending station is leaving (or has left)" - Roaming issue?
CB7
I have another question. This one has been driving me crazy for quite some time now and has been a noticeable issue since deploying Merlin - but I think probably has been a problem before, but I just wasn't paying attention to it yet. I've found various threads on the matter both here as well as on Reddit (most recent I think is this one: https://www.snbforums.com/threads/a...ess-clients-dropping.88646/page-2#post-924146) and you have tons and tons of suggestions. "The problem is beamforming!", "The problem is your iPhone!", "You need to select channel 36!" and none of it actually helped. So I figured I could find out what device may be the culprit, but upon closer inspection I see it doing this over and over again with multiple devices:
Nov 5 14:12:02 wlceventd: wlceventd_proc_event(662): eth6: Disassoc <MAC>, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Nov 5 14:12:03 wlceventd: wlceventd_proc_event(685): eth6: Auth <MAC>, status: Successful (0), rssi:0
Nov 5 14:12:03 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc <MAC>, status: Successful (0), rssi:-58
Nov 5 14:12:04 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc <MAC>, status: Successful (0), rssi:-82
Nov 5 14:12:04 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc <MAC>, status: Successful (0), rssi:-75
I found that rather interesting, as it disassociates with nearly half of the connected devices at once at exactly the same time; only a few of which are Apple. (In case it truly is the iPhone, but I don't have "private Mac" enabled to begin with, because I give static DHCP leases based on MAC-address - been doing so for years).
This begs the question: when it does the ReAssoc, it displays the RSSI. The -82 one for example certainly would be disconnected by it and -75 is on the border. (The -58 absolutely not).
... Is this problem simply caused by the Roaming Assistant? Or am I being too optimistic in hoping that nobody suffering from this issue in the countless of threads on it has thought of that? :p
I'd prefer to keep the Roaming Assistant on to give devices a little nudge out of the door when reception is on the border of the two AP's.
