If I restart my XT12 and my ISP modem at the same time, Discord either doesn't reconnect at all, or occasionally it'll appear to eventually reconnect, but then has issues loading profile/server pictures. If I restart Discord, it never connects. All other services appear to reconnect fine. This affects multiple devices.
Console logs in Discord show lots of 404 errors which suggested a DNS issue to me, so I set DNS on my PC manually to Google's and it fixed it (tested by restarting 3x - reconnected every time vs never reconnects with XT12 doing DNS). XT12 is also using Google DNS, the issue happens regardless of whether I use ISP's DNS or Google, Cloudflare etc.
I tried replicating the issue with an old Netgear router, just in case it was due to my ISP's modem, and that worked fine. The ISP router also works fine. ISP modem/router is Virgin Media Hub 5, it can be used either as a router or in modem only mode.
I've spent hours trying to fix this and it seems to be an issue with the XT12. FWIW I had the same issue with a TUF-AX6000, but I returned that for other reasons.
I have already tried the following which make no difference:
-Reset to defaults
-Changing DNS server from ISP's to e.g. Google
-Restarting Discord (including via Task Manager)
-Uninstalling Discord and reinstalling (without restarting PC)
-Updating Ethernet Driver RTL8125B to latest version
I have tried the following which only fix the issue temporarily and it will always return after the next restart:
-Disable and reenable Ethernet adapter in control panel
-Restart PC
Does anyone have any suggestions for how I can fix this? I'm already in contact with Asus and they haven't been very helpful so far.
-Reset to defaults
-Restart PC
