Hi everyone. I have ASUS AC87U with installed 380.64_2 by merlin.
Have a couple of problems
1. Disk check is not working everyday at 5AM. I've set up everything from GUI and in the morning I do not see check log in network map - disk - health scanner
2. have such problems in syslog
Jan 20 10:10:49 kernel: thfsplus: recoff 36325 too large
Jan 20 10:10:49 kernel: thfsplus: recoff 10228 too large
Jan 20 10:11:10 kernel: thfsplus: recoff 10228 too large
When I run check disk everything is checked and repaired cause disk has hfs+. I suppose these problems are from smb cause disk has Samba share.
3. And also has in log
Jan 19 20:07:47 kernel: BUG: Bad page state in process nvram pfn:9ccd3
Jan 19 20:07:47 kernel: page:c819ba60 count:0 mapcount:0 mappingnull) index:0x894
Jan 19 20:07:47 kernel: page flags: 0x9a000004(referenced)
Jan 19 20:07:47 kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c009d5e0>] (bad_page+0xb4/0x110)
Jan 19 20:07:47 kernel: [<c009d5e0>] (bad_page+0xb4/0x110) from [<c0376b80>] (get_page_from_freelist+0x4d0/0x58c)
Jan 19 20:07:47 kernel: [<c0376b80>] (get_page_from_freelist+0x4d0/0x58c) from [<c009e310>] (__alloc_pages_nodemask+0xe0/0x698)
Jan 19 20:07:47 kernel: [<c009e310>] (__alloc_pages_nodemask+0xe0/0x698) from [<c00ad9d4>] (do_wp_page+0xcc/0x7d4)
Jan 19 20:07:47 kernel: [<c00ad9d4>] (do_wp_page+0xcc/0x7d4) from [<c00afa58>] (handle_mm_fault+0x1d0/0x704)
Jan 19 20:07:47 kernel: [<c00afa58>] (handle_mm_fault+0x1d0/0x704) from [<c00452f4>] (do_page_fault+0x178/0x1ec)
Jan 19 20:07:47 kernel: [<c00452f4>] (do_page_fault+0x178/0x1ec) from [<c003d3a4>] (do_DataAbort+0x30/0x9c)
Jan 19 20:07:47 kernel: [<c003d3a4>] (do_DataAbort+0x30/0x9c) from [<c0387060>] (ret_from_exception+0x0/0x10)
Jan 19 20:07:47 kernel: Exception stack(0xcd29dfb0 to 0xcd29dff8)
Jan 19 20:07:47 kernel: dfa0: 4022b000 40232514 00000110 000003af
Jan 19 20:07:47 kernel: dfc0: 400f7140 00049000 400f7248 00000000 402614b4 bef74cb0 4008b000 bef7495c
Jan 19 20:07:47 kernel: dfe0: 00006378 bef74940 40236b0c 4008c7a8 20000010 ffffffff
What to do with all this stuff ? The main question how to repair disk errors and checks by cron? Thanks
