Diversion Diversion audits and traffic leakage?
brodas
Each time when i install an app on the iPhone devices they all ask for access to the access of the other devices on the local network.
If I install an app outside the local network this does not happen.
If I uninstall Diversion this problem stops happening.
So I ask: Diversion audits the traffic and leaks the audited data?
The Pixelserv blocking IP is a LAN IP, so if an app is having a domain blocked by Diversion, it would need access to the local network in order to be redirected to the local Pixelserv IP. Or just disable Pixelserv and use 0.0.0.0 as the blocking IP (Diversion Lite).
