Hi all. I've been trying to diagnose Diversion with my WellsFargo Mobile App. After opening the app and signing in, it closes immediately and says the service is not available. I disable Diversion and it works fine. I followed the Dnsmasq log and gave it my phone's IP. Diversion was blocking these 3 domains when I tried to log into the app:
dpm.demdex.net
device.4seeresults.com
analytics.foresee.com
I whitelisted these three domains and they were all found in the medium and large blocking lists. The problem with the app still persists, and when I follow the Dnsmasq log now, the issue still happens but there is no results from tailing the log. If I disable Diversion ad blocking it works fine.
As a side question, is it normal for it to take about 5 minutes each time you process the Whitelist?
Thanks gang!
Update:
Tailing the log some more, dpm.demdex.net is still being blocked. Trying to add it to the whitelist says that it's already in the Whitelist:
Enter selection [1-5 e=Exit] 3
i Press Ctrl-C to exit
14:27:11 blocked by blockinglist_fs dpm.demdex.net
Add domain like so: domain.com or www.domain.com
An explanatory comment can be added after this step
Enter domain [e=Exit] dpm.demdex.net
____________________________________________________
dpm.demdex.net
is already in whitelist
! Press Enter to return
Update 2:
I had to manually go and edit the two Blocking List files located
/tmp/mnt/sda5/entware/share/diversion/list# nano blockinglist
/tmp/mnt/sda5/entware/share/diversion/list# nano blockinglist_fs
And deleted the entries for dpm.demdex.net.
This was after confirming it was in the Whitelist and reprocessing the lists multiple times. Is this normal behavior? It was a lot of manual work when the Whitelist is supposed to delete those entries for me.
dpm.demdex.net
Thanks gang!
Update:
dpm.demdex.net
Update 2:
