Diversion Diversion device exclusion & Unbound
Dux
I'm not sure if I should be asking this here or the Unbound threads.
I have been using Diversion lite with a device exclusion for a while, the device skips Diversion ad-blocking & uses WAN DNS as expected.
I tried using Unbound via AMTM, default settings, devices globally use Diversion ad-blocking & Unbound as DNS resolver, tests show my IP as my DNS as expected. However, the device with the exclusion still uses the WAN DNS, not Unbound as DNS as I want to do for all devices.
Is there a way to set the device with the ad-blocking exclusion to also use Unbound?
Thank you.
