mikefrommanchester
I updated my firmware which went fine. Then I checked Diversion and it's telling me theres an update but it won't update.
Diversion 4.3.3 Lite
Diversion failed to update. Check the Diversion-web-update.log with sf in the SSH UI.
Current Asus Merlin firmware I'm on is latest: 386.14_2 for RT-AC86U
Anyone have any advice.
amtm - the Asuswrt-Merlin Terminal Menu
/mnt/SanDisk Size 1.8G Used 312.4M (18%)
1 open Diversion 4.3.3 -> v5.3
ep manage Entware packages -> 10p avail
fd run Format disk fdl show log
sh manage shell history
sw manage Swap file /mnt/SanDisk 250.0M
cj show all cron jobs
i show available scripts
amtm options
u update rr reboot
e exit t theme r reset a about
_____________________________________________
amtm updated from v3.7 to v5.0
Getting from fwupdate.asuswrt-merlin.net
- Module amtm.mod redownloaded
- Module diversion.mod redownloaded
- Module entware.mod redownloaded
- Module shell_history.mod redownloaded
- Module swap.mod redownloaded
For third-party script updates, use their
own update function.
- Module mount-entware.mod downloaded
Enter amtm option 1
Diversion 4.3.3 by thelonelycoder
RT-AC86U (aarch64) FW-386.14 @ 192.168.1.254
121,027 blocked domains by 1 hosts file(s)
3.209M t 6,306 w 3,563 n ads since Nov 28 17:20
/mnt/SanDisk | Size 1.8G | Used 312.5M (18%)
d Diversion Lite enabled
c communication DivUn stats backup FWun BL
a ad-blocking to IP 0.0.0.0
l logging dnsmasq.log 7.6M
ep entware packages
b blocking list Standard Wed @ 2:00
el edit lists 0 w 0 b 0 wb
tb type 65 blocking disabled
f follow dnsmasq.log
e exit u update more options o
____________________________________________________
What do you want to do? u
i Diversion 5.3 is now available!
Released on: August 11 2024
What's new in Diversion 5.3
See https://diversion.ch for change log
Do you want to update now? [1=Yes e=Exit] 1
i Getting latest diversion file (diversion.ch)
✖ diversion is not a Diversion file
! Diversion update detected
i Running function auto-update now
i Getting latest installer file (diversion.ch)
✖ install.div is not a Diversion file,
using existing file
i Checking router
✔ Asuswrt-Merlin
✔ Wireless router mode
✔ dos2unix
i Router check complete
i Probing for Entware
✔ Entware is already installed
i Getting Diversion Lite from diversion.ch
✖ functions.div is not a Diversion file,
using existing file
✖ helper.div is not a Diversion file,
using existing file
using existing file
✖ mount-entware.div is not a Diversion file,
using existing file
✖ post-conf.div is not a Diversion file,
using existing file
✖ rotate-logs.div is not a Diversion file,
using existing file
✖ update-bl.div is not a Diversion file,
using existing file
✔ webui.zip downloaded
unzip: invalid zip magic 4F44213C
✖ webui.zip extraction failed
✖ write-config.div is not a Diversion file,
using existing file
i Checking white and blacklists
✔ Whitelist
✔ Blacklist
✔ Wildcard blacklist
i Checking /jffs/scripts entries
✔ dnsmasq.postconf
✔ mount-entware
✔ services-stop
✔ unmount (Diversion)
✔ unmount (swap file)
✔ service-event (Diversion WebUI)
i Initializing Diversion
✔ WebUI remounted
✔ blocking list
i Restarting Dnsmasq
✔ Dnsmasq restarted
i Checking dnsmasq.conf entries
✔ Additional hosts
✔ Log facility
i Checking cron jobs
✔ cron file found
✔ blocking list update
✔ Rotate logs
✔ Ads counter
✔ Diversion Lite v5.3 complete
✔ install.div integrated
i Checking router
✔ Asuswrt-Merlin
✔ dos2unix
✔ functions.div integrated
✔ helper.div integrated
✔ mount-entware.div integrated
✔ post-conf.div integrated
✔ rotate-logs.div integrated
✔ update-bl.div integrated
✔ webui.zip extracted
✔ write-config.div integrated
✔ Whitelist
✔ Blacklist
✔ dnsmasq.postconf
✔ mount-entware
✔ services-stop
✔ WebUI remounted
✔ blocking list
✔ Dnsmasq restarted
✔ Additional hosts
✔ Log facility
✔ cron file found
✔ Rotate logs
✔ Ads counter
✔ Diversion Lite v4.3.3 auto-update complete
ep entware packages
amtm options
u update rr reboot
Enter amtm option 1
ep entware packages
using existing file
i Checking router
✔ Asuswrt-Merlin
✔ dos2unix
using existing file
using existing file
using existing file
using existing file
using existing file
using existing file
using existing file
using existing file
✔ Whitelist
✔ Blacklist
✔ dnsmasq.postconf
✔ mount-entware
✔ services-stop
✔ WebUI remounted
✔ blocking list
✔ Dnsmasq restarted
✔ Additional hosts
✔ Log facility
✔ cron file found
✔ Rotate logs
✔ Ads counter
i Checking router
✔ Asuswrt-Merlin
✔ dos2unix
✔ Whitelist
✔ Blacklist
✔ dnsmasq.postconf
✔ mount-entware
✔ services-stop
✔ WebUI remounted
✔ blocking list
✔ Dnsmasq restarted
✔ Additional hosts
✔ Log facility
✔ cron file found
✔ Rotate logs
✔ Ads counter
ep entware packages
