Diversion: How to block ads on Paramount Plus
rtn66uftw
Hi all. I want to block ads on Paramount+ while watching live sports on my Android/Roku TV. Right now I can't watch any live sports with Diversion installed. Streaming existing content worked on Roku devices only. On my computers, I had to disable uBlock origin to be able to watch live sports on web browsers.
How do I go about blocking ads on Paramount+? Thanks in advance!
This is the domain log from uBlock if it helps
    post    xhr    https://paramountplus.com.data.adobedc.net/    aliasURL=htt
    post    xhr    https://saa.paramountplus.com/va/api/v1/sessions/c580dd3
    get    xhr    https://dai.google.com/linear/hls/pa/event/4gifId1nStyTkCFn6
    get    xhr    https://a1939.dscz.akamai.net/    aliasURL=https://prope8f9224
    get    xhr    https://prope8f9224e.airspace-cdn.cbsivideo.com/out/v1/003a6
    post    beacon    https://vtg.cbsi.map.fastly.net/    aliasURL=https:/
    post    beacon    https://doppler-client-events.cbsivideo.com/v1
    get    xhr    https://vtg-global.cbsi.map.fastly.net/    aliasURL=https://dop
    get    xhr    https://doppler-tasks.cbsivideo.com/sessionconfig-v2.json
    post    xhr    https://bam.nr-data.net/jserrors/1/NRJS-b5dcb3a7b0855a31
    get    image    https://sb.scorecardresearch.com/p?c1=19&c2=3005086&ns_a
    get    xhr    https://vodc206gb6.airspace-f.cbsivideo.com/measurements/153
    get    xhr    https://rpt.cedexis.com/f1/_CgJqMRAUGHsiBQgBEKNUKNnj-KIKMIbx
    get    xhr    https://d2gwjqd6rjufw.cloudfront.net/    aliasURL=https://vod
    get    image    https://census.us-east-1.nielsencollections.com/    alia
    get    image    https://secure-dcr.imrworldwide.com/cgi-bin/gn?prd=dcr&c
    get    image    https://vod62c350g.airspace-g.cbsivideo.com/    aliasURL
    get    image    https://vod-gcs-google.cbsaavideo.com/measurements/r20.g
    get    xhr    https://a1893.dscw141.akamai.net/    aliasURL=https://vod62c3
    get    xhr    https://ap-hls-vod-cld.cdn1.showtime.com.c.footprint.net/
    get    xhr    https://ap-hls-vod-cld.cdn1.showtime.com/measurements/153619
    get    xhr    https://cs1858.wpc.nucdn.net/    aliasURL=https://vod62c350g.
    get    image    https://vod-gcs-edgecast.cbsaavideo.com/measurements/r20
    get    image    https://p36.cedexis-test.com.wsoversea.com/    aliasURL=htt
    get    image    https://d1inq1x5xtur5k.cloudfront.net/    aliasURL=https:/
    get    xhr    https://d1inq1x5xtur5k.cloudfront.net/    aliasURL=https://p29
    get    css    https://fonts.googleapis.com/css2?family=Mulish:wght@200;300
    get    image    https://pxc.ssl.star.optimicdn.com.c.footprint.net/    alia
    get    image    https://level3ssl.optimicdn.com/img/13070/r20-100KB.png?
Paramount Plus is picky with Ads and allowing streaming still. With AGH I had to whitelist a few domains to get adblocking to work whilst still being able to stream content.
Have you tried adding those same domains to the Diversion whitelist.
Blocking ads using Adguard or Diversion (or PiHole for that matter) uses DNS style blocking. This kind of blocking does not work with most streaming sites as those sites serve their own ads so DNS based blocking will not work.
I don’t use Diversion.
The adblocking works using AGH after whitelisting a domain or two to allow streaming but still block ads.
Head over to SlickDeals, get yourself a fresh Paramount+ premium trial (with a different email and a different credit card) - and you should be ad free for a few good weeks :D
What domain that you whitelist? Thanks
Used to do that but got tired of entering code every month :D
It's more like 3 months, 1 original trial, 2nd for cancelling then taking the extension, 3rd - they try to bill you but credit card is locked so they try billing you for a few weeks.
Entirely too much "work" for old man Griswald.
