Diversion not filtering Wifi
Mogsy
Hello,
Very new here. Just installed Diversion lite. I can see it is working via ethernet but not blocking anything with Wifi? What am I doing wrong? My main upstream dns is Quad9 with forward DNS to upstream dns selected no
Hello,
Hi, is your wifi devices has it’s own DNS? In order to use diversion, wifi devices DNS should set to your router IP.
Another way is to use DNSFilter. In GUI, under LAN -> DNSFilter, set Enable DNS-based Filtering to “ON” and Global Filter Mode to “Router”. This will force all devices to use your router as DNS.
Thank you. Did that. It is working on my laptop. But not working on my iPhone. I added lightswitch’s host and he has a test page for it https://block-test.developerdan.com/
I already disabled iCloud Relay on my iPhone too.
try switching from diversion lite to diversion standard.
I can't think why that would make a difference to WiFi clients. AFAIK all it would do would be to add a whole new layer of complexity (pixelserv proxy) and potential instability (dcd crashes).
Sounds more like a client (iPhone) issue, e.g. DoH.
@Mogsy After the change you made in post #3 is this affecting any devices other than the iPhone(s)?
Oh I agree, just one more layer to test. Most likely is a DoH service in the background of the device.
@Mogsy
Try adding
doh.dns.apple.com to your blocklist.
Hi guys. Sorry for late reply! Havent got a chance to properly look into this again. Had a quick look at Divstats only, I’m scared to configure dnsmasq tbh. Will look again when I’m home, only remembering that the block page was working on everything else but iOS devices. In divststs what’s type=65?
Will report back when I can
thank you!
thank you!
if you add
doh.dns.apple.com
to your diversion block list, then it should hopefully prevent your iOS devices from making auto DoH redirection. You should try it as soon as you are able and see if it resolves the seeing ads on iOS problem.
if you add
doh.dns.apple.com
I suspect he will still see ads due to DNS query type 65.
I still have this iptables rule to blanket block everything from this query type.
Another option is to go for AdGuardHome. AGH can filter ads from this query type by default.
adding
dns-rr=example.com,65,
to dnsmasq.conf.add appears to work.
if wildcard is supported, I imagine it could be simplified to
dns-rr=*,65,
nvm we explored this once upon a time. It must have been a day when I already had my coffee. ;)
Sorry!
Yes add doh.dns.apple doesnt work. I switched from Quad9 to NextDNS just to see the logs. Everything else is filtering except ios devices. How to I add that dnsmasq.conf.add please?
Sorry!
No problem here, Diversion, iOS, quad9.
On your Apple device check Settings>General>VPN & make sure there’s not a dns profile installed there.
If there is, that will override Diversion.
Sorry!
you need these iptable rules
iptables -I INPUT -p udp --dport 53 -d $(nvram get lan_ipaddr) -m comment --comment "DNS Type 65" -m string --hex-string "|0000410001|" --algo bm -j REJECT
iptables -I FORWARD -p udp --dport 53 -m comment --comment "DNS Type 65" -m string --hex-string "|0000410001|" --algo bm -j REJECT
otherwise you need to know the specific domains you are trying to block the 65 dns from.
Or use AdGuardHome.
Or use AdGuardHome.
Thank you. Will try this in a bit. I would like to try Adguard Home. I installed it on my friend’s AX86U. I only have AX86S, and the RAM is above 90%
No profile installed. Limit IP address tracking off too
Or use AdGuardHome.
iptables: No chain/target/match by that name. :(
