Diversion not working with mesh nodes
jambogabe
Hello,
Using merlin wrt in an Asus AX86U-Pro as the router. Two nodes (AC86U and AC68U) are connected via ethernet backhaul as AIMesh nodes. Diversion is installed on the router.
Ad filtering works while I'm connected to the router, but on the two nodes it does not work.
Any insights?
Thanks, Gabe
Hello,
Any insights?
Thanks, Gabe
Check the browser to make sure it is not using DoH or DoT. Also enable DNS Director on the router set to router.
I was fail... Realized I had set up a manual DNS for my laptop I was using via the other access point so it was bypassing the router settings. Thanks.
