Hello all.
Came across this forum recently and thought i would share my build and ask for a few opinions on it.
My main goal for this build was to be able to stream 3 simultaneous BD rips to three clients on my network. The math on the average bit rate of bluray movies vs the available bandwidth of gigabit LAN works out with room to spare so i went about putting together a disk subsystem that can saturate the GB LAN link.
RAID is a forgone conclusion here for speed and so i went with RAID 5 for redundancy mostly because backing up 4TB of data is not cheap or easy so i keep it live and redundant. My RAID controller of choice here is the 3ware 9680SE PCI-E. This is a 8 drive SATA RAID controller and supports up to RAID 6 on 8 drives.
Hard disks were a concern, Enterprise drives are expensive but fast and robust. I ultimately chose 8 750GB Seagate ES2 SATA drives (expensive but fast!).
The rest of the system consists of 2 Icydock 5 in 3 disk enclosures, an Intel DQ965WH mainboard and Intel Core 2 duo E6600 (2.2GHZ per core) with 4GB or DDR2-800.
For the OS i went with what was familiar to me, Windows server 2008.
Initial testing puts the array at over 100MB/sec on local transfers (disk to disk in the same system) and ~45 -65 MB/Sec over the LAN for reads.
