Dlink DGL-4500 & Netflix
jam116
I recently purchased a Dlink DGL-4500 and XBOX wireless adpator "N". I can stream Netflix while wired with no problem. When I go wireless it will play about 10 minutes and freez or loose connection.
I upgraded to newest firmware....Running Windows 7 on a 64 bit machine
:confused:
It's not unusual that wireless connections have problems streaming video, especially if you're trying to do HD.
You need to check the speed of your wireless connection and the bandwidth that your Netflix stream is trying to use. Info on how to do that is here.
You also could have interference from cordless phones, microwaves or neighboring networks. You may need to do a site survey. See
How To Fix Your Wireless Network - Part 2: Site Surveying
