Dennis Wood
Well, I finally gave up on daily resetting the wireless on a Dlink DI824 VUP router and ended up picking up a DIR 825 REVB dual band router to replace it. Those who've poked around here for a while know that I had tested several dual WAN routers and settled on a Draytek 2950G for business use. The DIR 825 router is in this case for residential where simultaneous dual band "N" radios were desired as well as uPNP. In this application, VPN endpoint was not required. Tim had tested the DLINK DIR 825 and folks seemed happy with it, so I picked one up.
Here are two comments that may help anyone having issues with installation.
Problem 1: Out of the box, just like a NETGEAR FVS336 dual WAN router I had tested, SIP was broken. In other words, all of my SIP devices stopped working. This includes a Talkswitch VOIP phone as well as several iPhone SIP programs we use.
The fix was beta firmware which is not mentioned on the DIR-825 product support page:
http://forums.dlink.com/index.php?topic=8956.0 -> NA Version
http://forums.dlink.com/index.php?topic=9161.0 -> EU Version
EDIT: beta01 firmware is replaced: ftp://ftp.dlink.com/Gateway/dir825_revB/Beta/Firmware/
Problem 2: The router dropped connections to the DSL provider after 60 seconds and connection for those 60 seconds was flaky. A call to the provider yielded nothing. Resets, reloading firmware etc did nothing.
The fix:
Change the DIR 825 WAN port speed from "Auto" to 10Mbps which in this case matches the Speedstream 5260 DSL modem's ethernet port. This modem came from the provider and is apparently a bit dated. This was a guess based on a few years of experience...and it worked.
It's amazing how much time yet again gets sucked up dealing with hardware/firmware issues. It seems every time I touch a piece of hardware lately it costs me way too much time. In any case, hopefully folks googling similar issues will find this. On the positive side, the wireless range on this unit is a lot better than the DI-824 VUP unit it replaces.
Cheers,
The fix:
Cheers,
