Hi
I have a VoIP/SIP box that I am trying to get working behind my RT-N66U running latest Merlin. I thought it would be easiest just assigning a static IP and enabled DMZ for that IP.
If i plug the box in the network outlet without using my router everything works just fine BUT if I plug in the router and the box in one of the LAN connection of the router outgoing calls don't work.
Based on this I just assumed that DMZ isn't exactly like bypassing the router 100%.
Any ideas?
Regards
Joakim
Any ideas?
Regards
Joakim
