DNS-based filtering: is it really working?
vrapp
I tried a number of malicious URL's found at https://www.malwaredomainlist.com/mdl.php
With AI Protection/Malicious sites blocking, practically every URL was indeed blocked.
With AI Protection/DNS filtering/enable dns-based filtering = on, not one was blocked. I tried all providers - Yandex, Comodo, Opendns, and Norton. Also tried "router" with Opendns's dns specified at WAN page. So I'm wondering, are they all so inefficient compared to TrendMicro, or something does not work, or I did something wrong?
Here it is, with opendns configured.
You might try setting the global mode to Router and then on the WAN page setting the 2 DNS servers to the OpenDNS Home IP addresses ( 208.67.222.222 and 208.67.220.220 ?) and leave everything else as it is and see if that produces the desired effect.
I doubt that OpenDNS would be as efficient as Trend Micro's Reputation database.
Also one big difference is AiProtection's reputation system works on the whole URL, not just the target server. See this post from Asus's engineer regarding WRS. A DNS can only filter on the hostname, it can't analyze the whole URL.
Yes, did that as well: "Also tried "router" with Opendns's dns specified at WAN page". Same result.
you might want to catch DNS requests if you want to use DNS filtering. Using RMerlin's firmware and IPTables look at hijacking DNS requests.
I think it's actually even simpler. Run nslookup of a domain hosting known malware using supposedly-protecting dns service. If it returns different IP than google's 8.8.8.8 , then it does protect. I tried that, and they all return the same IP. This makes me wonder what their claim of protecting anybody from anything is based on. If I'm not mistaken, they all have a similar commercial product.
