DNS blocked no matter the server?
sbsnb
I have this weird issue where I cannot resolve sce.com no matter what servers I use.
> sce.com
Server:  dns9.quad9.net
Address:  9.9.9.9
DNS request timed out.
    timeout was 2 seconds.
*** Request to dns9.quad9.net timed-out
> sce.com
Server:  dns.google
Address:  8.8.8.8
*** Request to dns.google timed-out
It's not an issue reaching the servers since they work for any other domain.
> snbforums.com
Address:  9.9.9.9
Non-authoritative answer:
Addresses:  2606:4700:20::ac43:4551
          2606:4700:20::681a:942
          2606:4700:20::681a:842
          104.26.8.66
          104.26.9.66
          172.67.69.81
> snbforums.com
Server:  dns.google
Address:  8.8.8.8
Addresses:  2606:4700:20::681a:842
          104.26.9.66
          172.67.69.81
          104.26.8.66
It's been this way for days. The strangest thing is that when I check the status of sce.com from other Web sites it appears to be up and running with no trouble. When I traceroute to sce.com's IP space it looks fine.
Any ideas what the heck?
What's even more strange is that if I try to ping sce.com from the router UI it has no problem resolving.
PING sce.com (45.60.136.211): 56 data bytes
64 bytes from 45.60.136.211: seq=0 ttl=57 time=76.306 ms
64 bytes from 45.60.136.211: seq=1 ttl=57 time=76.223 ms
64 bytes from 45.60.136.211: seq=2 ttl=57 time=76.438 ms
64 bytes from 45.60.136.211: seq=3 ttl=57 time=76.377 ms
64 bytes from 45.60.136.211: seq=4 ttl=57 time=76.433 ms
--- sce.com ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 76.223/76.355/76.438 ms
From the router:
admin@RT-AX86U-AE24:/tmp/home/root# nslookup sce.com
Server:    208.67.220.220
Address 1: 208.67.220.220 dns.opendns.com
Address 1: 45.60.136.211
Address 2: 45.60.77.211
From a LAN client:
> sce.com
Server:  resolver2.opendns.com
Address:  208.67.220.220
*** Request to resolver2.opendns.com timed-out
Figured it out. It was a layered issue involving DNS filtering.
parental controls?
There was a post recently about nxdomain timeouts...
In any case, works fine here... with Cloudflare DNS over TLS...
dig sce.com
; <<>> DiG 9.10.6 <<>> sce.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 39034
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;sce.com.			IN	A
;; ANSWER SECTION:
sce.com.		900	IN	A	45.60.136.211
sce.com.		900	IN	A	45.60.77.211
;; Query time: 61 msec
;; SERVER: 2606:4700:4700::1111#53(2606:4700:4700::1111)
;; WHEN: Sat Sep 03 17:17:46 PDT 2022
;; MSG SIZE  rcvd: 68
XIII ICANN reserves .internal for private use at the DNS level Other LAN and WAN 2
