DNS confusion - hosts file has a bunch of stuff in it
5mall5nail5
Hey all,
So I am having issues pinging by name and am trying to figure it out.
In LAN settings I have the device name as conway.local and it's 192.168.50.1 it was called "Asus" before.
If I go to the clients link from Network Map I see a 19 clients connected, all MAC addresses except for a couple probably because only a few have updated DHCP since rebooting or something. I see Chromecast in the clients with an IP. So I go to cmd and "ping chromecast" I get this:
C:\Users\me>ping chromecast
Pinging chromecast.Asus [192.168.50.148] with 32 bytes of data:
Reply from 192.168.50.148: bytes=32 time=7ms TTL=64
Reply from 192.168.50.148: bytes=32 time=5ms TTL=64
Reply from 192.168.50.148: bytes=32 time=12ms TTL=64
So, its resolving chromecast.asus not chromecast.conway.local - ok, hm.
So then I SSH to the router at 192.168.50.1 and cat /etc/hosts and this is what I have:
me@conway:/tmp/etc# cat hosts
127.0.0.1 localhost.localdomain localhost
192.168.50.1 router.asus.com
192.168.50.1 www.asusnetwork.net
192.168.50.1 www.asusrouter.com
192.168.50.1 RT-AC66U.Asus RT-AC66U
What's with all the entries? Is that standard? Why isn't there anything about conway.local in here?
I'd like to get DNS sorted so I can use machine names on my network but something seems amiss.
Thanks all
edit: I think I have this a little confused - device name is the hostname here and then domain name under DHCP is what I want?
edit2: Ok so I have the device name set back to Asus, domain name is conway.local. I have 6 raspberry pi's set for static IP of 192.168.50.50-192.168.50.55 all hostnames are "raspiN" so 0 - 5. On client view on network map I see the MAC's but no resolution. I added entries to hosts like so:
jkensy@Asus:/tmp/etc# nslookup fiosrouter
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 192.168.50.2 FiosRouter.conway.local
me@Asus:/tmp/etc# cat hosts
192.168.50.1 Asus.conway.local Asus
192.168.50.40 BeagleSQL1.conway.local BeagleSQL1
192.168.50.41 BealgeAPP1.conway.local BeagleAPP1
192.168.50.50 Raspi0.conway.local Raspi0
192.168.50.51 Raspi1.conway.local Raspi1
192.168.50.52 Raspi2.conway.local Raspi2
192.168.50.53 Raspi3.conway.local Raspi3
192.168.50.2 FiosRouter.conway.local FiosRouter
So now I can ping by FQDN and hostname but do not see any resolution on the clients page. How can I get that to resolve? It'll be easier and more convenient.
Thanks,
Jon
