AndreiGuru
Hello,
I was wondering if a checkbox can be added in the DNS Filter page, to also redirect port 853 instead of dropping packets if they're not for the same filter IP? Pretty much all of the preconfigured DNS services now support DoT and DoH, and I run a pihole VPS which I forward my DNS through. Since redirecting DoH isn't an option, I was wondering if you could add a simple DoT checkbox on the page, and change the rule to forward instead of drop. I know it can be done manually, but it would be nice to have a gui option and not have to hack around the reject rule added in DNSFILTER_DOT. For example, when I enable it in the GUI, I see these rules added:
# iptables -t filter -nvL DNSFILTER_DOT
Chain DNSFILTER_DOT (1 references)
pkts bytes target prot opt in out source destination
0 0 REJECT all -- * * 0.0.0.0/0 !dns.filter.ip reject-with icmp-port-unreachable
# iptables -t filter -nvL FORWARD 11
0 0 DNSFILTER_DOT tcp -- br0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:853
# iptables -t nat -nvL DNSFILTER
Chain DNSFILTER (2 references)
5492 394K DNAT all -- * * 0.0.0.0/0 0.0.0.0/0 to:dns.filter.ip
# iptables -t nat -nvL PREROUTING
Chain PREROUTING (policy ACCEPT 10027 packets, 2213K bytes)
1326 81062 VSERVER all -- * * 0.0.0.0/0 wan.ip
5459 392K DNSFILTER udp -- * * 192.168.1.0/24 0.0.0.0/0 udp dpt:53
34 2040 DNSFILTER tcp -- * * 192.168.1.0/24 0.0.0.0/0 tcp dpt:53
