DNS Filtering-add withe and black list
pepeEL
Banned
Hello
In settings DNS filtering is option to set: Custom 1 , Custom 2 and Custom 3. What is it and which pages this set block ? Can i definied pages manual ? How ?
Maybe good option to DNS filtering in GUI is add option to user can manual definied withe or black pages which is open or block ? For example user set Norton DNS Filter and some pages in this set is block. User want this page is open. Then add this page to White List and then router filer DNS by Norton but this one page open. The same as block page... which example Norton open but user want to block it.
Merlin what you think about it ?
Hello
Whitelisting is the dns server's job with DNSFilter, not the router's.
Sent from my Nexus 4 using Tapatalk
Ok but how i can add custom web address to DNS Filter ?
And what is set Custom 1 Cusotm 2 and Custom 3 ? How it work and how i can configure it ?
You have to go to the OpenDNS, Norton, Comodo, etc. website and add them there. As RMerlin just said, whitelisting is not done on the router.
Here you can specify the IP address of DNS servers not already listed.
Ok but where i must Type this IP address?
Wysłane z mojego SM-G850F przy użyciu Tapatalka
Now i ask about Custom 1,2,3 ? This is from OpenDNS ? If yes shoud be rename to OpenDNS Custom 1, OpenDNS Custom 2, OpenDNS Custom 3
No.
https://raw.githubusercontent.com/RMerl/asuswrt-merlin/master/README-merlin.txt
** DNSFilter **
Under Parental Control there is a tab called DNSFilter. On this
page you can force the use of a DNS service that provides
security/parental filtering. This can be done globally, or on a
per device basis. Each of them can have a different type of filtering
applied. For example, you can have your LAN use OpenDNS's server to
provide basic filtering, but force your children's devices to use
Yandex's family DNS server that filters out malicious and adult
content.
If using a global filter, then specific devices can be told to
bypass the global filter, by creating a client rule for these,
and setting it to "No Filtering".
DNSFilter also lets you define up to three custom nameservers, for
use in filtering rules. This will let you use any unsupported
filtering nameserver.
You can configure a filter rule to force your clients to
use whichever DNS is provided by the router's DHCP server (if
you changed it from the default value, otherwise it will be
the router's IP). Set the filtering rule to "Router" for this.
Note that DNSFilter will interfere with resolution of local
hostnames. This is a side effect of having devices forced to use
a specific external nameserver. If this is an issue for you, then set
the default filter to "None", and only filter out specific devices.
