DNS Privacy Protocol (Supported Devices)
duyfken
Which ASUSWRT routers support DNS Privacy Protocol (DNS over TLS)?
My new RT-AX1800S running ASUSWRT 3.0.0.4.386_69037 firmware doesn't have the option
Screenshot 2023-12-29 at 18-28-03 ASUS Wireless Router RT-AX1800S - Internet Connection.png
I believe the routers on 388 code base have DoT. And you may have to spend more than $69.00 . Look at the router specs on the Asus web site.
Check the spec webpage for the model you are interested in.
Security
DNS-over-TLS
OE
