Solved DNS Rebind Attack Message For Only Two Domains
HarryMuscle
I use ControlD for my DNS servers which return 0.0.0.0 for blocked domains so I've added the following to my dnsmasq configuration via the dnsmasq.conf.add file:
bogus-nxdomain=0.0.0.0
however, for some reason I keep getting the following messages in my logs every few seconds:
Nov 15 15:03:33 dnsmasq[2721]: possible DNS-rebind attack detected: multiscreen.samsung.com
Nov 15 15:03:35 dnsmasq[2721]: possible DNS-rebind attack detected: cdn.samsungcloudsolution.com
I don't get these log entries with any other blocked domains so I'm thinking something strange is going on with these two domains but I can't figure out what. If I run nslookup for these domains against the ControlD DNS server they do indeed come back as 0.0.0.0 so it shouldn't be triggering a rebind warning but it is. Is there any way to get more details from dnsmasq about why it thinks there is a DNS rebind attack? Or is there something else I could look into to try to get to the bottom of this?
Thanks,
Harry
Turns out I also needed to add this to the dnsmasq.conf.add file
bogus-nxdomain=::
even though I have IPv6 disabled adding this fixed the issue above. I'll leave this here in case anyone else comes across a similar problem.
Thanks,
Harry
bogus-nxdomain=::
Thanks,
Harry
You might want to add “[SOLVED]” to the start of the title so that anyone looking for an answer in future - which you’ve kindly given - can instantly home in on your topic.
You probably want to disable rebind protection if you’re using a filtering DNS provider. Otherwise, you will eventually see more blocked domains give the same warning message.
You can also resolve this by using this statement:
echo "rebind-domain-ok=/plex.direct/" >> /jffs/configs/dnsmasq.conf.add
service restart_dnsmasq
