DNS slows down after up too long?
Claghorn
I have an asus RT-AC5300 with 380.59 merlin firmware. It was up and running continuously for a few weeks, with mostly no problems, but then I started noticing that on some sites (in particular http://www.npr.org/sections/news/) it would load the text instantly and the images would sometimes take several minutes to follow.
As an experiment, I rebooted the router, and now the images and text both load instantly. I'm wondering if there is a known problem with the dnsmasq version getting tired or something if it is up too long?
Just one data point, so it may be coincidence, but I thought I'd ask.
Or maybe it really is the web site. It has already started happening again after just 1/2 hour or so. I'll have to remember to check it at work tomorrow on a completely different network and see if I see the same thing.
Default dnsmasq TTL set too long? Normally this is handled upstream, but dnsmasq is a caching DNS server, and the --min-cache-ttl value might be set a bit long...
