dnsmasq.conf.add - if statement to examine "tag" value
Frank Herman
It seems reasonable to think that you should be able to use the "tag" value within an "if" statement.
The "dnsmasq.conf.add" file below does not work, any ideas on what I am doing wrong??
dhcp-host=set:green,20:aa:30:bb:2E:cc,pc1,192.168.1.2,infinite
dhcp-host=set:red,00:aa:E8:bb:96:cc,pc2,192.168.1.3,infinite
IFI = $(tag)
if [ $IFI -eq "green" ]; then
address=/www.youtube.com/216.239.38.119
address=/m.youtube.com/216.239.38.119
address=/youtubei.googleapis.com/216.239.38.119
address=/youtube.googleapis.com/216.239.38.119
address=/www.youtube-nocookie.com/216.239.38.119
fi
The "dnsmasq.conf" file is not a script, it is a parameter file for dnsmasq.
Also, your question is specific to Merlin's firmware ("dnsmasq.conf.add") so the "General Wireless Discussion" forum is probably the wrong place for it.
I was hoping to fix the issue where my (2) ad blocking assignments are being negated because of the DNS server assignment (dhcp-option) lines below.
Is there another way to bypass the "youtube restrictions" below, for only "pc1", without loosing the ad blocking assignments?
This is my dnsmasq.conf.add file;
# ignore unneccesary windows requests
filterwin2k
# AD BLOCKING
# ad block list from -> https://github.com/notracking/hosts-blocklists
conf-file=/jffs/configs/domains.txt
addn-hosts=/jffs/configs/hostnames.txt
# CONTENT FILTERING
# assign ip id's to mac id's
# set DNS server
dhcp-option=tag:green,option:dns-server,8.8.8.8,8.8.4.4
dhcp-option=tag:yellow,option:dns-server,208.67.222.222,208.67.220.220
# youtube set to -> restriced mode (.120) -> restriced-moderate mode (.119)
