dnsmasq entry pointing to internal ip not working
untarded
I just purchased the ac68u and flashed 378.50.
I've enabled dhcp and enabled jffs scripts. I successfully added a dnmasq.conf.add which appended the dnsmasq.conf file on reboot:
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
interface=ppp1*
no-dhcp-interface=ppp1*
resolv-file=/tmp/resolv.conf
servers-file=/tmp/resolv.dnsmasq
no-poll
no-negcache
cache-size=1500
min-port=4096
dhcp-range=lan,192.168.1.100,192.168.1.149,255.255.255.0,86400s
dhcp-option=lan,3,192.168.1.1
dhcp-option=lan,252,"\n"
dhcp-lease-max=253
dhcp-authoritative
address=/foobar.com/192.168.1.160
But I can't get foobar.com to point to my internal ip.
Anyone else doing this? I don't know where I'm going wrong.
Since you are trying to assign a DNS name to host you should use the hosts file and not the address directive which is used to override entire domains.
user=nobody
bind-dynamic
interface=br0
interface=ppp1*
no-poll
no-negcache
cache-size=1500
min-port=4096
dhcp-lease-max=253
dhcp-authoritative
Not 100% sure, but have you tried
server=/foobar.com/192.168.1.160
