Dnsmasq local hostnames with IPv6
Nazar78
Hi all,
I have the RT-AX86U 386.3_2, recently configured with IPv6 Tunnel 6rd, DHCP and RA enabled but I have issues resolving IPv6 in clients hostnames.
Strange is querying the router's hostname does return IPv6 but not the rest of the clients hostnames:
C:\Users\nazar>nslookup RT-AX86U
Server: RT-AX86U.RT-AX86U
Address: 192.168.1.1
Addresses: 2400:d803:XXXX:XXXX::1
192.168.1.1
C:\Users\nazar>nslookup MEG-Trident-X10
Address: 192.168.1.3
Below is my default dnsmasq.conf, I've tried changing the dhcp-range from ra-stateless to ra-names then restarting the daemon:
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
no-resolv
servers-file=/tmp/resolv.dnsmasq
no-poll
no-negcache
cache-size=1500
min-port=4096
domain=RT-AX86U
expand-hosts
bogus-priv
domain-needed
local=/RT-AX86U/
dhcp-range=lan,192.168.1.2,192.168.1.254,255.255.255.0,86400s
dhcp-option=lan,3,192.168.1.1
dhcp-option=lan,6,192.168.1.1,8.8.8.8,0.0.0.0
dhcp-option=lan,15,RT-AX86U
dhcp-option=lan,252,"\n"
ra-param=br0,10,600
enable-ra
quiet-ra
dhcp-range=lan,::,constructor:br0,ra-stateless,64,600
dhcp-option=lan,option6:23,[::]
dhcp-option=lan,option6:24,RT-AX86U
dhcp-authoritative
interface=br1
dhcp-range=br1,192.168.101.2,192.168.101.254,255.255.255.0,86400s
dhcp-option=br1,3,192.168.101.1
interface=br2
dhcp-range=br2,192.168.102.2,192.168.102.254,255.255.255.0,86400s
dhcp-option=br2,3,192.168.102.1
addn-hosts=/etc/hosts.dnsmasq
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
dhcp-script=/sbin/dhcpc_lease
script-arp
How can I have IPv6 returned in the local clients queries without putting static names in the host file or using address=/foo/bar? Appreciate any advice, thank you.
Hi all,
here is an example line for use in dnsmasq.postconf
pc_replace "dhcp-range=lan,::,constructor:br0,ra-stateless,64,600" "dhcp-range=lan,::2,::500,constructor:br0,slaac,ra-names,64,600" $CONFIG
Thank you very much! After setting this I can start to see the IPv6 in the lookups. I was looking for a solution for quite some time before posting. Thank you again.
